This isn't a Land Cruiser, but the injector pump appears to be similar to the one on the H diesel in my HJ45. This one is off of my IH 274 cultivator tractor (made by Komatsu in Japan). It's running a Nissan SD16. The feed pump is labeled "Kiki 05220-4950" I seem to be having a misfire along with a sever lose of power during times of heavy load/ high fuel use. It could also be a crack in the head pre comb. chamber, etc. as I believe these issues are associated with high engine temp, but I don't have a temp gauge to check this. It really seems like it is starving for fuel. If I leave it and come back the next day it starts and runs fine until under heavy load. Bleeding the injectors does not help.
This has happened to me a couple times and I've changed the fuel filter(current filter has <30 hours), but mostly this tractor is used for cultivation witch is a low engine speed, low engine load task. It's only after mowing for 5 hours yesterday after I begin driving straight up about as steep of grade as the tractor can climb. I have also been siphoning fuel out of a bus that hasn't moved in the past 8 years, but the most recent fuel I put in the tank camp from a gas station pump. I emptied the sediment bowl today and it was fairly clean. My HJ has been running the same siphoned fuel with no issues.
My questions are: Does this seem like fuel supply issues? Should I rebuild my feed pump and if so what is the part number for that kit?
I'm trying to attach some photos, but that doesn't seem to be working for me.
