FishNinJay
I'm going to learn to weld, so that I can build a rear bumper mounted swing-out Spare Tire Carrier very similar to this:
My plan is to use 2"x2" 1/4-inch like in the pics. This needs to be sturdy, as it will be supported entirely by the bumper-mounted heavy duty hinge on the passenger side, and Grade 8 bolts into the frame crossmember beneath. This needs to support a pretty big spare, 33x12.5x15, Toyo Open Country MTs. I'll probably also add a cooler carrier.
My small garage only has 120AC power (as far as I know..)
I was originally thinking of buying the Lincoln Electric Power MIG 140C Welder, but I saw this Chicago Electric 90Amp Flux Wire welder at Harbor Freight Tools for $119.99
Flux Wire Welder - 90 Amp <~~ link, click it!
THIS WEEKEND, for Father's Day, it's on sale for $89.99
Yeah, I know.. Harbor Freight = cr@p .. right?
I'm reading that with better flux wire, like the Lincoln Innershield, there is much less spatter and cleaner welds with the HFT 90A flux wire welder. What do you think?
I've been researching, and it seems like FCAW welds thicker metal, but may have some porosity and impurities? I don't care if it looks ugly. MIG looks nicer, less impurities, but can only weld thinner metals (Why is this? Can't you lay down additional layers?) Some say FCAW is only for emergencies, field work, etc. Others say most buildings steel structures are done with FCAW so it must be hella strong, right? Am I overthinking this?
My question..
Given my intended use, weight of my spare+bumper, and 1/4-inch square tube I plan to use, is FCAW flux wire welding strong enough? I can't have this thing snap off on the highway and land in some lawyer's Porsche convertible.
Or, should I go with gas MIG welding?
I have a few other future welding projects in mind.. including cutting a fold-n-tumble rear bench in half to widen it to custom fit into my FJ40. I think I only need to make 4 cuts into pretty narrow square tube frame rails. Weld in angle iron extensions. I have a decent inexpensive re-upholster place to restuff and re-upholster it. I'm less concerned about weld looks or weld strength here.
Any advice for the -welder?
My question..
