hey there folks, does anybody know if the diff centres out of a 80 series wagon will fit into hzj75 ute diff housings? are they the reason for the taller overall gearing or is it in the gearbox?
thanks
thanks
thanks for that, i am just looking for taller gearing, IF my ute has 4.11 gears std and so do the 80 series, why do the 80 series cruise at 100km per hour at less rpm than my ute?
that just leaves the speedo, is it a matter of swapping the drive gear like an old ford or is this an electronic adjustment?
the gear swap in the diff should produce about 250rpm engine speed drop at 100km per hour based on my approximate calculations...2500x3.7/4.11=...
might be good to know if the gearbox swap will be possible 1, and 2 more cost effective, i have a H55F trans, genuine manual does not indicate ratios in the box or if a 80 series one will fit without problem. diff code on the tag is K085 which i believe is 9.5", 4.11, LSD 4pin is this right?...all the info for the diff came off american sites dealing with hilux/pickup and tacoma vehicles.
60 series has full size front diff, yours has baby front diff
