fan shaft can wiggle w/ my hand
Discussion in '60-Series Wagons' started by t100boy, Feb 19, 2009.
  1. t100boy
    t100boy
    106
    13
    May 26, 2005
    Tulsa, OK
    It wiggles when I grab a fan blade and try to. It seems to growl like metal against metal when idling,THERE WAS A FAN BELT SQUEEK THAT WAS NOT THERE BEFORE AT IDLE. when you throttle up is holds the shaft straight but still growls
    IS THE WATER PUMP GOING?
  2. fliphkd778
    fliphkd778
    991
    5
    Mar 10, 2007
    Hmmm...Usually when a pump is going, it will weep out of the 8-9 o' clock position.
  3. Man Jerk
    Man Jerk
    2,112
    7
    Jun 28, 2002
    Colorado Springs, CO
    Sounds like the bearing for the waterpump may be bad.
  4. t100boy
    t100boy
    106
    13
    May 26, 2005
    Tulsa, OK
    so the bearings are going that means the pump is going to fail next right?
  5. Man Jerk
    Man Jerk
    2,112
    7
    Jun 28, 2002
    That would be a fair assumption. You don't want your water pump to sieze.
  6. IH8Wood
    IH8Wood
    949
    2
    Dec 3, 2004
    Altadena CA
    My water pump bushing went bad and my fan ended up in my radiator. You should fix yours soon.
  7. Joe_E
    Joe_E
    3,552
    Media:
    39
    Albums:
    1
    152
    May 31, 2008
    the NJ word..
    I am a firm believer in changing out wobbly bearings especially in water pumps.
    Flashback to around 1992....as a crewmember of my buddies racing team I find a somewhat slight wobble in the water pump via grabbing the fan after winning the heat race.
    Ahhh it will be alright...
    Flash ahead to leading the feature with a couple laps to go with a good lead...
    Pooooof she goes up in steam.
    Fan , pump , radiator, hoses, belts, you name it all trashed.
    Bye bye trophy and 500 bucks
    Change it.
  8. tsototh
    tsototh
    300
    1
    Jun 20, 2007
    Tuscaloosa, AL
    The first question should be... Did you check and make sure the nuts holding on the fan blade are tight?
  9. t100boy
    t100boy
    106
    13
    May 26, 2005
    Tulsa, OK
    yes my er the nuts are tite. I heard a change in the sound of the fan belts THEY HAD A SQUEEK THAT AT IDLE THAT WOOD GO AWAY AT HIGHER RPMS. THE PULLEY AND SHAFT WERE WIGGLING CAUSING THE SQUEEK AT IDLE. SO LISTEN TO YOUR BELTS THEY DO TALK WHEN THEY NEED HELP
  10. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,199
    Media:
    180
    Albums:
    8
    520
    Mar 31, 2006
    Central California
    Your fan clutch could be going bad. Grab the plastic blades of the fan near the clutch and see if it wiggles on the shaft.
    If it is going bad, it can knockout the waterpump over time do to an out of balance situation.
  11. t100boy
    t100boy
    106
    13
    May 26, 2005
    Tulsa, OK
    replacing water pump, tstat hoses, getting rad repaired so many say replace I guess I will find out....
