First of all -- thanks to all of you regulars and others out there ... I hope you appreciate what a valuable resource your contributions have helped build. This place has made a lot of tasks very approachable for me as a newby since I picked this LC up 1.5 weeks ago.
I have the belts, fan, radiator, and battery/battery box out due to oil pump seal and front CS seal change. I just want to ask the mudders if there is any other recommended PM/ baselining I should do before I put all of that stuff back in.
Coolant and hoses generally all looked pretty good. Did not see any sludge from the rad or block drain (at least from what was caught in the bucket.
I suppose I should check the PHH while I have the coolant out.
I will be flushing the coolant system with distilled water once back together and then will do a good undercarriage cleaning before moving on to the front axle rebuild.
This is on a 2004 locked w/ 178k on it. It will be my DD.
Thanks,
Grady
Thanks,
Grady
