- Joined
- Feb 18, 2002
- Messages
- 326
I searched and I couldn't find what I am looking for.
I have a 1967 FJ40, with a 1984 2F from an FJ60. I currently have the 60 series 2F water pump with oil cooler, fan clutch and fan. The problem is the fan is too big to fit inside the shroud, and I would rather not modify the current shroud.
The Fan measures about 18" in diameter, and the shroud is about 17" in diameter.
My question, is there a fan out there that will bolt up to the 60 series fan clutch and is smaller in diameter to clear the shroud; or a shroud that bolts up to the radiator support and has a larger diameter opening to clear the larger fan? The fan has enough clearance between the radiator, so the length is not an issue.
Thanks,
Thanks,
