fan clutch identification, grey fluid? (1 Viewer)
tunica, ms
anybody recognize this clutch? and is this fluid full of aluminum shavings, or is it a different kind of fluid that was used?
tunica, ms
97' 80 with 157k
depends on your definition of functional. the truck wasn't overheating, but there was very little resistance at operating temps.
80t0ylc
Hill & Gully Rider
Canyon City, OR
97' 80 with 157k
OK, at least it wasn't seized up. Did you get the "roar" at startup (1st start after sitting all night)? If you did get the roar, that would say that it was still capable of engaging.
I don't think that clutch is an Eaton. By comparing it to photos of the Eatons in landtank's thread, the fastener holes look different. The drive plate has 6 holes on yours and I haven't seen that in any photos here. From the condition of your fluid and given the difficulty to clean up the silicone fluid, you probably would be better off to replace it. If you can get your hands on a used Eaton or Aisin in good condition and drain and refill per the fan clutch threads here on Mud. They were OEM equipment clutches. Or pull the trigger on a new blue adjustable through Cdan. I'm no expert, but Kevin (Tools R Us) is the fan clutch guru. You might PM him to get his opinion.
Chandler, AZ
The tolerances have to be very close, precise machining/assembly, for clutches to properly function. In this case it looks like parts are contacting each other, the gray/black is alloy particles, from parts rubbing on each other that shouldn't be.
That clutch looks like one from a local rig, that was removed after a very short life and had poor performance. When opened had the same problem, it is an aftermarket POS, get an Aisin or Eaton.
In the 3rd pic it's evident where this one was rubbing.
Tapage
Club 4X4 Panamá
Panamá
about the fan clutch .. it's any way to measure the performance of the fan clutch . ? in order to determine if it's working good or not ..
e9999
Gotta get outta here...
Moderator
US
well, yes, there is the infamous "stick your hand in the fan" method that I used. Not recommended, use at your own risk! :)
Tapage
Club 4X4 Panamá
Panamá
I use a cardboard .. :D but the FSM must have some kind of measurement for that .. ( even if they recommend use your finger :hillbilly: )
