Family tops - what are you using for rear support?
Discussion in '40- & 55-Series Tech' started by Brian in Oregon, Feb 23, 2007.
  1. Brian in Oregon
    Brian in Oregon
    3,040
    9
    Dec 17, 2005
    The obvious way to run a family top is with a full cage. But I only have a cab cage. If anyone else has a cab cage only, or even just a roll bar, how are you supporting the rear of your family top?
  2. Fast Eddy
    Fast Eddy
    14,301
    1,995
    Apr 5, 2006
    Morgan Hill, CA
    Replicate the factory rear hoops
    Look in the corners of your tub. There threaded holes in the corners of the tub. Two on the flat part and two up by the rim. The bottom bracket, 170, is a raised circle that holds the base of the tube and 175 is just a bent strap that holds the tube against the tub. Both brackets are bent sheet metal.
    [​IMG]
  3. Brian in Oregon
    Brian in Oregon
    3,040
    9
    Dec 17, 2005
    I actually have a pair of 170's, given to me by Colorado Boy. Looking for a pair of 175's. I dunno if the rear hoop is readily available, though. The ultimate solution would be to just get the entire setup as shown in the diagram.
  4. Fast Eddy
    Fast Eddy
    14,301
    1,995
    Apr 5, 2006
    Morgan Hill, CA
    I'll bet you could get damn close with a some electrical conduit and a Home Depot bender. The 175 bracket is trivial to make. The Toyota one is surprisingly bland. I know where there's a pair of both in a wreck, but I don't have power there to cut off the rusty bolts.
  5. Coolerman
    Coolerman SILVER Star
    6,116
    Media:
    2
    Albums:
    1
    1,021
    Jan 5, 2004
    Paint Lick, KY
    Yeah I wondered what happened to those! :D
  6. Colorado Boy-74-FJ40
    Colorado Boy-74-FJ40 I may grow older but I refuse to grow up!
    1,466
    83
    Aug 5, 2005
    Windsor Colorado
    Hey Brian,
    Why dont you install that factory OEM front roll cage hoop you showed me and use that for rear support?
  7. gladly
    gladly User title
    1,019
    32
    Apr 16, 2005
    here's an idea from another thread
    [​IMG]
  8. Brian in Oregon
    Brian in Oregon
    3,040
    9
    Dec 17, 2005
    I've thought about it, but I'm not sure I want to put holes in the floor for it. Particularly if I might extend the cage later with something more substantial.
    On the other hand, if I mounted it to a plate and spanned the OEM top holes in the wheel well tops over to the existing cage mounts, and got four sets of the OEM rollbar pipe clamps, I could make a lightweight cage like shown in glady's cage. That would work until I decide wwhat to do permanently. I haven't found a source for four sets of the pipe clamp T's, though.
