Failed smog check
Sin City (Vegas)
I just finished a top end rebuild. I installed EB street/RV head and Erson camshaft. I followed top portion of Wristy's "Failed Smog Check" guide except for the valve clearances. Camshaft recommends .008/.008; should I reset to factory settings of .008/.012 to pass smog, or will that work. Also found black soot on plug #4.
Thanks in advance !
RPM HC Limit/ Reading CO Limit/Reading
___________________________________________________
2500+ 220/221 Fail 1.20/.53 Pass
Idle 775 220/382 Fail 1.20/1.54 Fail
MORE DETAILS:
I had problems with my smog check today and was hoping for some experienced input.
I passed smog last year but I have just finished installing EB's Street/RV head, a new cam, cap, rotor, wires, etc. I have a slight miss and found black soot on one side of the #4 plug. I turned everything by hand after installation and all felt smooth, no binding, etc.
(Cam Spec: Erson T268A cam, 210° @ .050", .436" lift, .008/.008)
I followed Wristy's checklist except for resetting the valves. If I reset valves to stock .008/.012 what difference will it make on the exhaust emissions if any, or is it just a burn problem ?
I have been told that If I spend $450 for a DMV certified technician to try and correct this and it doesn't pass, I am eligible for a waiver; If I try it and can't pass I get nada.
Went through checklist and FSM, made adjustments to AFM , dashpot and Valves, replaced all vacuum lines w/ the spiffy blue silicone hoses. Passed all but the HC at 2500+.
Now I need to figure out why the ignition is missing at higher RPMs. I have new Toyota cap and rotor, new NGK wires, new plugs gapped to stock spec. I cleaned and checked distributor as per FSM.
Any ideas ?
I'm purely guessing but:
Recheck spark plug wires are fully seated. Check your ground wires and the brackets that hold teh coil/ignitor and make sure they are tight. Also it is possible to have arcing inside the distributor. A scope machine at teh smog shop would probably show the reason to you.
