Factory tubular tire carrier handle a 33" spare? (1 Viewer)
Oregon
Can a factory tubular tire carrier handle a 33" diameter tire? A BFG 33/10.5-15 to be exact.
At one point I had a 33/12.5 mud terrain as a spare on different truck with the factory tubular carrier and I recall it sticked out past the body a bunch. I recall the driver side mirror had greatly reduced visibility. I ended up swapping it out for a 31".
Is anyone else running a 33-in size diameter tire as a spare on the tubular tire carrier? Does it stick out past the body a ridiculous amount?
Cariboo BC
I run a 33" spare on my tire carrier. It is a unicorn 9.5 wide and doesnt stick out much. A previous owner even added a spacer to push it out further to accommodate wider tires and it still looks alright.
spotcruiser
Geezer
Western WA
I bent the original tire carrier significantly on my trail rig when the spare hooked a tree on a tight trail. So I extended it inboard 3" and no longer have a problem with it.
I just added 3" of 1" tube to the horizontals on the right (where the ty-wraps are on the upper piece).
The bottom cushion was just unbolted on the left, rotated 180, and a new bolt hole drilled. I also moved the latch 3" to the right.
KY
What condition is your body in at the tire carrier mounting points?
I mention this because once you go above stock tire sizes the life of your body at the tire carrier mounting points is going to be seriously shortened. The factory body was not built to support the size and weight of over sized tires and wheels.
If you want to keep your body sheet metal in good shape seriously consider an aftermarket tire carrier which is better suited for larger and heavier tire/wheel combinations. Stay away from ones which attach to the tub sheet metal because eventually the sheet metal will fail.
You may think your solution is only short term but many times once it is put in place it will remain that way unit it fails and it will.
Food for thought, what is the price of a new tire carrier versus the cost of a new tub or sheet metal repair and paint.
Oregon
Thanks for the pics @spotcruiser. The rig in question is a restoration, she's going to be all factory with a few mods, such as 33's. At this point I am not into modified body parts. But thank you.
Oregon
I couldn't agree more with you on the sheet metal aspect. I ended up building shims that keep the tire carrier from clamping down on the outside of the rear fender. When the tire carrier bolts are tightened it snugs itself against the backing plate, which is located on the inside the body, instead of the fender / paint on the outside. It's really hard to explain but it works very well.
I may just end up running a 31-in tire as a spare.
Idaho Savage
GOLD Star
Idaho
Bumping as my 70 doesn't have a spare carrier. Has anyone put this style (80+) on the older model, like a 1970?
I'd rather not spring for a CCOT bumper or the like and am open to exploring all alternatives.
3_puppies
Helena MT
it is easy to do with all the parts, drill some holes, I would add large backing plates on the inside of the tub
which rear barn door opens first? if the driver side, every time you want to open the rear you will need to open the spare tire
