Only the cool kids have the factory switch.......I feel stupid..... Of course Joey has a solution!
Thanks
I'm still on the fence between the factory switch or ARB lockers.........
Are you cool?
Thanks
Are you cool?
Who let you in here?!?If its not factory, its not factory.....I prefer to ARB switches as it is functional and easy to engage.
lol...sup brotha.??Who let you in here?!?
Man, there has to be a dozen or so of us who have switched from BMWs to 4x4s. You, me, Kevin, Geordie, and several more that I recognize from back in the day. Lots of other guys from CA too.lol...sup brotha.??
I am still a bmw guyMan, there has to be a dozen or so of us who have switched from BMWs to 4x4s. You, me, Kevin, Geordie, and several more that I recognize from back in the day. Lots of other guys from CA too.
I've got plans to run my Harrop ELockers through both the factory switch and the factory 4wd ECU. I want to modify the factory switch to add a third "front only" position, and modify the ECU to provide the standard globe check on start-up and flash if the lockers don't actually engage like the factory ones do, while allowing the front lockers to engage separately, which is normally locked out. Looked into it already, and it's definitely doable. If the microcontroller in the ecu isn't a rebadged programmable one, which I'll be able to figure out once I get it on the bench, I'll map out the behaviour of the stock chip, write a replacement program on a modern microcontroller and drop it in its place. All to get that nice "FR" position on that dial. Total overkill, needless amount of work, but everyone needs a hobby!
I already know if I actually do this mod, I'll probably never use it in my life. Never once when wheeling have I actually thought to myself "I really wish I could engage just a front locker right now". I don't even have the lockers in the car yet, just prepping for it actually. This is mostly just a random fun project I'm interested in doing because I can, because nobody will have done it before, and because I want to have the ultimate answer to anybody I hear in the future complain about the factory rotary switch not supporting front only.
You might be giving 1990's technology a little too much credit.If the microcontroller in the ecu isn't a rebadged programmable one, which I'll be able to figure out once I get it on the bench, I'll map out the behaviour of the stock chip, write a replacement program on a modern microcontroller and drop it in its place.
How do you plan to detect when the Harrops are actually engaged?...and modify the ECU to provide the standard globe check on start-up and flash if the lockers don't actually engage like the factory ones do...
Very familiar with tech from the era, I reverse engineer and repair 80's and 90's arcade and console hardware for the fun of it.You might be giving 1990's technology a little too much credit.
I had one of the diff-lock ECU's open and, IIRC, there's no actual microcontroller, just a simple logic chip driving the relays. The Harrops will require external relays as well, so in the end you may find there is little reason for using the factory ECU.
The factory lockers use a mechanical switch to detect when the lockers are physically engaged. There's no equivalent for the Harrops, but I was planning to check for a closed circuit on the magnetic switch. Easiest way would be to reverse the second pair of relays, so when the locker relay is closed, if there's a closed circuit on the return path, engage the second relay, which will act as the "locker engaged" signal. That'll be sufficient to make the lights flash if power isn't successfully flowing across the magnet, such as from wiring damage or the harness being disconnected.How do you plan to detect when the Harrops are actually engaged?
