Cruzin -
Welcome to the list !
>> if it [tire carrier] will fit on the US models...
Yes, the factory (OEM) carrier will fit... but there is a greater issue. The trucks - primarily in the Japanese Domestic Market (JDM) had additional, interior structural support in the body panels that is absent on the U.S. trucks. So, yes it will fit, but would not be safe without considerable modification.
>> locate and buy a factory swing away rear tire carrier from japan ?
Yes, but because of the shipping weight it would likely be prohibitively expensive
>> cheaper than just buying a kaymar or slee one?
There would other reasons for using the Kaymar / Slee bumper mounted carriers that you need to factor in, such as the option of using a second swing gate, an integrated hitch (Kaymar), departure angle, recovery attachment points (Slee), additional rear collision protection, etc. So, it is not a straight forward comparison.
Also, there are other, non-factory non-bumper mounted rear tire carriers to consider. You need to search around a bit to see what is available.
BTW, when posing questions to the list, it is often most helpful to know what year truck you have, milage, mods you may have made , etc. Helps in getting more precise answers.
Cheers! R -
