Hello All,
The factory front diff lock on my '97 will not turn off or disengage while plugged in at the axle end. If I disconnect the two plugs on the front axle that are in the locker area then the front locker disengages and the dash light goes out. If those two plugs are connected the dash light never goes off and the front locker remains engaged including light front tire squealing when turning on pavement. Shifting the transfer from high or low has no impact on the front diff locker engagement that I can tell.
The locking knob works properly for the rear diff locker including only engaging the rear after the transfer is shifted to low range and after a bit of blinking. Turning the locker switch and shifting the transfer case seem to have no impact on the front locker which remains engaged with a solid light on the dash.
I'll get into the FSM and troubleshooting soon but wanted to find out if there are any obvious places to start on this issue. For now I've disconnected the two sockets on the front axle to avoid damage to the front end while driving on pavement.
Thanks,
Thanks,
