The method that I have had the best results with is: Blow on the spring with a heat gun (hair drier would probably work, but slower) until the valve is full open, turn off heat. Measure spring temp with an IR gun, watch the temp as it cools/valve closes to determine the temp at first opening.
I don't have an IR gun, so I'm wondering if the thermometer next to the spring is accurate?
I'd think that using a heat gun and slowly warming up the spring with an adjacent thermometer would be accurate. But do you know if the 120° as measured by that method would be the same as 120° measured using the water method?
