They are reversed, B has the lower on the drivers side, upper in the pass. F is opposite... Or is it the otherway?
I think you could get away with using a F in a B because you have so much room just get a pre shaped hose that would work. B on a F no way.
Im pretty sure the reason why the 'B' series radiators changed is due to the introduction of power steering.
It looks as though power steering wasnt available until 10/81. Up until then the upper radiator hose joined the radiator on the RH side. After 10/81 it changed with the upper hose swaping to the LH side of the radiator. The reason no doubt was due to the fact that the B series mounted its power steering pump/pulley to the front RH side of the cylinder head - which would have fouled the earlier radiator hose setup. The lower hose joined the radiator on the LH side through out.
You guys are aware that any competent radiator shop can move the outlets around, right?
We just had the F series radiator modified to work with our B.
Dan
