F motor water pump replacement ?'s (1 Viewer)
Dixon, Ca
I am getting ready to replace a howling water pump on my stock f motor. Should i put permatex on the gasket between the pump and gasket?
JohnnyC
Long ago TLCA# 2231
UpState Ny, Wells Me
what type of permatex are you asking about?
i put permatex high tack spray gasket on when i do that type of gasket....but...not blue rtv or ultra copper
wonder what others do :hmm:
OEM pump and gasket with a thin skin of Toyota F.I.P.G. aka Form in place gasket
Shane
Dixon, Ca
and you guys put the permatex or form a gasket between the gasket and the pump or between the gasket and the block?
Murphys, CA
When I replaced mine recently, I followed the advice of 65swb45 (Mark of Mark's Offroad) which was the following:
- Unscrew the back plate off the water pump. Apply a small bead of rtv silicon on both sides of the gasket and reattach.
- Between the water pump and block I did not use a gasket. I applied a bead of rtv silicon around the water pump hole and torqued to specifications.
This worked for me.
Brian
Craig, CO
I've used blue silicone on mine, both sides of both gaskets. They always seem to form a leak after several years on the upper drivers side, lack of bolts there I think. Shows as a seep and antifreeze residue. The better form a gasket stuff from Toyota is probably pretty good. Used a simlar product from Ford on oil pans for the 40, and I-6 Bronco engine many years ago. No leaks what so ever, good stuff.
I also use actual permatex thread sealant on a couple of the bolts for the water pump. I think it is the lower couple, can't recall. But these bolts pass through the block and into the water jacket, they can and will leak around the threads. I'm pretty sure factory manual indicates this.
