F motor questions
Discussion in '40- & 55-Series Tech' started by 890man, Aug 2, 2005.
  1. 890man
    890man
    848
    143
    Jul 7, 2005
    Petaluma,Ca.
    While driving home after a long weekend I hear a loud pop followed by reduced power, a lot of vibration and loud clanging sounds from the engine. Not good. Pulled the valve cover, everything looked good. I turned the motor on and the oil was comming out of the rockers but quickly turned it off. The sound from the lower end was a tinny clanking sound. I have not had the chance to pull the pan yet to check the bottom end or check compression and won't be able to until next week. With that said, here is my question. I have found a motor out of a '70 fj55 for a good price. Are the heads, manifolds, accessories, brackets etc interchangeable between this motor and my f motor in my 12/74 fj55 (late model f). I didnt really pay attention to the differences when I saw the motor because I wasnt in the market at the time. The one thing I did notice, was the oil fill. Mine is on the valve cover and the other was on the side. Any help or search ideas would be great. I don't want to just drop in a V8. A diesel would be nice!!!!
  2. Poser
    Poser Oh...Durka Durka Durka. s-Moderator Supporting Vendor
    20,429
    Media:
    17
    Albums:
    1
    875
    Oct 1, 2003
    MN
    Welcome.
    The engines are interchangeable, as are the accessories.
    Drop the pan and figure out what is going on.
    Good luck!
    -Steve
  3. red dirt squirt
    red dirt squirt
    181
    1
    Jul 13, 2004
    Oklahoma City, Oklahoma
    fyi, i will be picking up a stock f engine on the 14th if you need parts just pm me and i will tell you what's left.
  4. Degnol
    Degnol
    8,121
    Media:
    16
    Albums:
    1
    27
    Jan 22, 2003
    Kansastitty
    The head from the early F and the late F oil differently. The late F oils like a 2F.
    Like wise, if you put the head from your late F on the early shortblock, it will not oil the rockers. Manifolds are no problem.
    GL
    Ed
  5. 890man
    890man
    848
    143
    Jul 7, 2005
    Petaluma,Ca.
    Thanks for the info. I understand that the later model f head will work on the 2f for a higher compression setup. Is this true? It was because of this I suspected there might be a difference. I will post my findings next week when I get back into town and have a chance to pull it apart.
  6. Bunger
    Bunger
    1
    Jun 13, 2005
    i have a rebuilt f motor
    If interested i have a complete long block been sitting for 3 yrs has 6000k on it pulled it for a V8 has headers weber advance distributor and i live in sausalito
  7. 890man
    890man
    848
    143
    Jul 7, 2005
    Petaluma,Ca.
    I may be. Tell me more. What year? What do you want for it? Whats it out of? Not all real important stuff (except the price), just curious.
    Thanks, Travis
