F engine upgrades???
Henderson, Nevada
Hey all,
Anyone know what I can do to get more power out of a 74 FJ40 F engine??? It has a Weber 38/38 carb., and a pertronix electronic ignition coil conversion kit on it. Don't get me wrong, the pig runs fine. I just want to know if anyone has any upgrades on a F engine like mine that you guys/gals can share that'll help out in the long run.
Thanks All!
Jeremy
alot of guys say use the asin carb instead of the webber.
turbo it (search turbo 2f in the hardcore corner).
Get rid of the weber. It will always run very rich. Get a rebuilt Asain. The F is like any other motor, good carb, tune it up, good valve adj, adv the timing a bit etc... A clutch fan will help a little bit. I have had good luck with aftm ignitions like MSD or Jacobs but it is not an amazing difference. Headers and a larger exhaust will help a little bit but not really cost effictive if your current exhaust is good.
Are you looking for bolt-on stuff or rebuild stuff? All the usual head work/ head shaving will help if you match to a cam, intake and exhaust mods. However you are not going to get much of a seat of the pants difference unless you go up in displacement or used forced induction.
Thanks.
Right now i'm in the process of rewiring my pig with a painless setup. After that i'm looking into headers and exhaust since they're all shot. I looked up the 2f turbo on the hardcore and it seems interesting...but will an F engine hold up??? Bolt on and rebuild are both in mind.
Thanks again!
Jeremy
In either case, its a very long crank with a few bearings. Balance the rods and pistons, line bore the block and it should live fine with modest boost and low rpms. I'm contemplating a turbo build up having read the same post, but I need to do more research. On the import tuner sites, they take A/R ratios, displacement and several other facors into account to size the turbo to the engine and desired rpm operating range. If we just put any old T04 from ebay on it without doing the math, we could end up with a dog motor with a turbo that adds nothing in the 1500 to 3000 rpm range of the F and 2F motors. I have both F and 2F cores and will rebuild the 2F motor because of the full filtration oiling. I will part out the F motor for cheap.
do you have the external oil lines on your F?
If not you have the mighty 1 1/2 F! ( or 1.5 F or F n' a half...)
It's a good motor with updated oiling. Still not as good as a late 2F, but good none the less.
My 74 is de-smogged (what little smog was on there anyway... :rolleyes: ) bored .040 over, balanced including flywheel, milled to approx 10.5 to 1 compression, mild cam, SS valves, petronix, MSD, 6 into 1 headers, and Jim C rebuilt carb.
it's a little rocket! :D
Now if I can get rid of this 3 speed, I might be able to shift easier... :D
seriously, it's a very strong engine that I would compare to a stock or mild V8.
Hey Chris,
I Dunno if it has external oil lines or not (not sure really). Can you give me a description? Pic maybe? It's a F from a september 74 so it's gotta be more "refined" than the later ones until 2F's.
Yah Trevor...I know but i'd like to keep my 74 a 74 without alot of fuss...lol. (Cowa Chief!)
Look for the oil lines going to the oil filter base
Jujoo said:
Hey Chris,
There is a lot to be said for that theory but then you talk about turbo and if it will work yet dont know if it externally oiled?????????
Go back to the basics, tune up, timing etc... Do a compression test first and a oil pressure test. Fs are known for low pressure and externally oiled Fs have a regulator that you can use to adj the pressure.
There is good reason to rebuild a F if you want a true stock truck. Other than that there is no reason to rebuild or sup up a F when a 2F is so much better.
Carbs and exhaust can help a tired F come back to life for a while.
I've got an Aisen core on the way. It will go off to one of the specialty rebuilders on the forum in a few months. A Tri-Y header is also enroute. I had Weber carbs on my previous Mitsu truck. 14 MPG from 2.6 liters hauling 3900 lbs, always ran rich and backfired despite having it "tuned". The senior forum members know their stuff and it is smart to follow their advice rather than strike out on your own ideas. Chances are someone here has already tried it ---twice.
I really like the F/2F motors in cruisers, but if you aren't happy with the power in a hot rodded F, you won't be any happier modifying it more. Just bite the bullet and put a TBI or TPI 350 V8 in it and be done with it. About 50% of cruisers have one in it anyway.
I second the Aisan carb, the Tri-Y header [just not $ORs] AND, once you have the carb and header on, something a little different with the stock dizzy. It's a little secret I pass on to my customers. ;)
Thanks for all the info all.
This is the reason I joined up on the forum...makin' sure I don't screw up my pig!!!
How much can I get an Asin carb for??? Anyone able to give me a link to a place other than $OR, Man-A-Fre, etc??? I've been lookin' at Tri-Y's too since the exhaust and stuff connected to it looks to be shot.
Thanks again,
Jeremy
I first rebuilt my late (12/'74) F maybe 12 years ago. I was still smogcheckable, so I couldn't do much to the inside. All my upgrades had to be bollt-on and reversable. I had it bored and balanced of course, ported the head and intake manifold. Used Downey headers and a '68 dizzy with the Pertronix guts. Fiddled with my Aisin a lot. On the mechanical secondaried carb (that you should have) you can tweak the rod to have your secondary open earlier.
It ran fine. Tached a little higher a little quicker, idled down and chugged just like it should.
Gave me many years of reliable service, but it was no hotrod. And it was getting tired.
So I built a 2F. With a Late F head. Bored .050 over, balanced as before, Federal-Mogul pistons, Sealed-power rings, RV cam, more headwork and new everything inside. Bolted on all the previous upgrades, added a Toyota Hi-Po intake manifold and my first official Jim C. carb. That made a difference. Now it really moves. Tachs to 3500 routinely around town, goes to 4500 up an onramp without complaint, there may be more there but I haven't checked yet. I had some pre-detonation issues, nothing good gas couldn't fix.
Moral: You can get just a bit more power out of your Late F with bolt-on stuff and good tuning.
But for anything noticable, you gotta get the whole package. Intake, compression, displacement, innards, ignition and exhaust all need improvement if you want something more than tractor engine performance out of your straight six.
Thanks Pighead,
That's what i'm looking for. Now all I have to do is just take it part by part because I don't want a 2F just yet. Just an F that's been tuned really well with some bolt-ons to get...what else..."cruzin"!
Happy Holidays and Merry Christmas All!!!
Jeremy
