F carb parts
Fernandina Beach, FL
Rebuilding my Aug 72 FJ40 carb and discovered that the carb is missing the parts for the high speed valve stop lever. Found the part numbers needed but TPD says they are discontinued. Any ideas of where I might be able to find new or used? Thanks.
Post a pic or circled diagram if you can. I have some parts carbs as well
Which part numbers? I have a partial F carb so I may have what you need.
Here's schematic with missing parts circled.....
That lever goes into the larger of the two holes, do you by chance have the smaller lever/spring that goes in the smaller hole (where the M5 goes)?
Sent a pm. I do not think your model had the lever with the spring. I have only seen that on earlier carbs (circa '69).
