Whelp, I need help to unravel a mystery.
In the tear down of a ‘70FST I’ve come against an issue.
F block is cast with 60030-11411
F serial stamping is stamped F__________. Blank
There appears to be a later head that I can not identify. (Casting numbers 60036 and 0413212)
-There are holes in front of and behind the manifolds (near the radiator and the firewall) indicating a non F head.
-No air rail holes
-Top end of engine has silicone toxicity
-Compression check indicates 150 psi +\- 5 psi per cylinder
Can someone tell me
According to prior posts from @FJ40Jim, the larger chamber of a 2f head on F block negatively affects the already terrible compression ratios of these engines
Thanks in advance for the assistance
hOOter
-No air rail holes
Can someone tell me
- what head do I have?
- what head gasket do I use?
- should I run it as is or get a true ‘f’ head?
hOOter
