F.5 head on 2F engine (4 Viewers)
As I understand, a domed piston with an open ( .5 head from 1974) configuration has higher compression than a flat piston with a closed configuration. Probably a domed piston will not work with a close configuration.
Do you already have the closed head? If so, you can measure the diameter.
Really appreciate it. It appears to me that the 74 head is kind of a crosd between open and semi closed chamber.
I took her on the freeway for the first time today, going 75 mph. She sounds like she could go a little faster, but the 55 mph speed limit is stopping me from pushing her further. She also has 7.00x15 tires, which make for a bit of a bumpy ride.
Surprised at the stock compression numbers. Compression makes power!! Thank you for shating.
stock compression is 135-160 (dry) with f.5 head compression from 170 (dry) and higher..
This time, I checked the compression correctly (dry).
1: 180, 2: 180, 3: 185, 4: 185, 5: 180, 6: 185
idle vacuum -20 inHg (at 650-660rpm) timing set at 11 degrees BTDC
really good numbers, when last i checked I was in the 135-140 range and like 16-17 on vacuum
I'm just trying to find out why there's oil on the second spark plug and what kind of gas she needs.
Oil on plugs is from the rings. Maybe your oil control ring is plugged. Let a good dose of Marvels mystery oil soak in for several days. Then take it out for an Italian tune up
I haven't noticed the engine burning oil... I can try Marvels oil soak.
This is how the pistons looked before I swapped the head — about 300–400 miles ago.
I cleaned and installed a rebuilt head from a '74.
I didn't touch the block, only cleaned and put a new gasket.
Is it just me, or does the second piston look a bit greasy and oily? If so, it is more likely the ring issue.
MMO might free up sticky rings - could take several treatments - maybe thin some with acetone to help it penetrate. Soak for a day or two then go burn it out, soak R/R Cheap, likely not to cause damage.
Broken or worn out ring(s), damaged piston/bore... you can't fix that so easily or sadly cheap. The longer you wait the more damage you can cause.
After 2 days of treatment with MMO (I need to add MMO multiple times, because it drains every 8 to 10 hours)
Compression increased from 180 to 190
I have run the engine for 30 minutes (regularly accelerating to 2K rpm)
Smog is still coming out after this, but much less.
I checked the cylinder: there’s oil on the piston and the spark plug
Hmm.. valve sealing or still oil ring?
I hear a clicking noise in the rocker arm area for about 30 seconds during a cold start (around the second cylinder).
How long does it take to burn it out?
Not very long. I leave the spark plugs out and use the starter to whirl it over so it can blow out as much as can.
Now that may be what I am looking for. I need my FJ40 to maintain 65-70 up hills and be able to pull a 5spd overdrive transmission. Easy to do with a V8 swap, but the stock six might be good enough.
Thank you
Mike Haberthur
I have fresh rebuilt 2F -5spd and you’re dreaming if you think your going to pull 65-70 up hill….slight incline no problem, kingsbury grade not happening.
