EZ-wire to stock wiper motor question
Golden, CO
Help me out it you can. I've got a 72 cruiser (and the diagram) and an EZ mini-21 kit. I'm almost done but am unsure about the wiper wiring. Cruiser diagram shows power to the wiper motor and not to the switch. My non stock wiper switch shows power (B) to the switch with 6 posts coming off.
Is this a three speed wiper motor? can I bypass the power to the motor and run power to the switch and then out to the motor via the other 3 wires??
Thanks in advance for your help.
come on you wiring wizards! :clap:
Thats the problem, I don't have the stock switch and so need to integrate the new 'chevy' style switch into the harness. Any tips?
I don't know a lot about the wiper wiring, but I do know that the ground is supplied through the switch. Constant 12v is supplied to the wiper motor through the ignition switch/fuse panel. Ground is supplied through the switch. Not sure just where the ground ultimately comes from, maybe the windshield frame.
Hope this helps
edit: just noticed your post about using a Chevy switch. Can you describe the switch? Is it the switch on a GM steering column? Adapting a GM column to a 71 FJ40 is where I learned what little I know about the Toyota wiper wiring.
One power for the low speed, one power for the high speed, one power to the self-park( these all come from the switch) and one ground....may come from the switch, but I just grounded mine.
Does that make sense?
Ed
Holy cowpies batman, I bought the same harness and had that exact question floating thru my head. Degnol, can you be more specific on which ones go where? I'm gonna use the stock 73 switch and it has 5 post's on it. I am stumped at this point. :confused:
It has been a long time since I wired that, but I'll try to get pics tomorrow. I did not have the female plug (no harness)so I terminated with female spade lugs and was able to mix-n-match until I got it right. I do remember using a multimeter to sort out the switch and the motor. Too many bottles of Wild Turkey ago:doh::D
Ed
Ed
I hear ya brotha, I hear ya. I wish I had kept a journal on what I did and why I did it, cause sometimes I look at things on the truck and say to myself " what the hell was i doing here ". Anyway, any help you can provide on that wiring would be appreciated. :beer:
the stock wiper motor shows a power wire (B) from the fuse box, and then 3 wires from the stock switch. My dash switch has a power in (B) a washer terminal (W) and 1,2,3,4,5,6 off the back. its a universal switch, has just off position and 2 clicks to the right and push for washer. Not sure what all the extra posts are for??? Its the switch I got from EZ wire but they are not responding to my emails requesting a wiring diagram for the switch.
That is where the multimeter/continuity checker comes in handy.;)
Dunno about the extra posts are for, maybe intermittent wipers?
Ed
According to the toyota diagram the motor is self grounded (I'm guessing to the windshield frame. Then there is the blue power wire off the fuse box and a blue-black,blue-red, blue-white coming from the switch. 4 wires total. For my switch I have power in and 1-6 off with a W for the washer pump (which I am not using) as there is no more room under the hood for a washer tank :)
So it seems that the motor needs power and that the switch stock switch just directs the current...but that won't work with the new switch.
I was wondering if I need to split the power line from the fuse box and hook it up to the power wire to the motor as well as send it to the switch and then run wires from 1-3 posts out to the other 3 wires on the wiper motor.
I'm really confused!!!!:bang:
Does your wiring work now? If so, just replace the hot wire to the B terminal of the wiper motor. No need to fool with the rest.
I agree,
Last night I had a sespose to this . It would have been the 3rd in this thread , but the bodyman came a long and we started yaking and I never posted it.
so I will post .
You are going to reverse the wires going to the motor, correct?
I don't know about the paritcular switch you are wiring ,but If you can do that , why not reverse the wires going to the switch and have the switch wired like a stock switch.
Here is how the stock switch is wired.
The lead to the motor is the solid color ( Blue?) the is common to the 2 speeds and park.
Then 3 wired are going from the switch to the motor , these will be the grounding wires ( Blue/w ,Blue/r, blue/b?) .
Then there are 2 wires (Blk/w) is the ground feed to the switch and (Blue/y) feed ground from the switch to the washer motor.
If you are going to reverse the wiring you need to ground the wire that was originally the lead to the motor. This should be the first step in your approatch.
Then you will have have to revesre the 2 wires going to the washer motor. Here I think you are going to run to problems , but may be that switch doesn't do the washer.
Anyway Use the multi to see how the switch works then if you
can wire it like the stock wiring.
If you reverse the wires to the motors, wouldn't that make them spin opposite direction , it wouldn't matter for the wipers , but what about the washer. I can post a diagram if you need it.
Vic-
Thanks for the post, a diagram would be great. So do I run power to the switch and groud the hot to the motor?
The diagram that I have is for stock stuff.
Do it like you were planing. The lead from the fuse to the common lead of your switch.
Then the Blue wire from the motor to good grounding source.
The your Blu/b will be park
and Blu/r , Blue/w are the 2 speeds. Run those to wires from your switch.
You are not wiring the washer so no problem,
You will have an extra wire you don't need. That i guess would be the third speed.
In the diagram one of the Blue/w wires could be blue/r in your motor.
Thanks, I'll give it a try.
wired it up as mentioned and flipped the switch.....snap crackle, pop!!!
New harness is in and here are the problems
1) right turn signal doesn't work-I suspect the switch is bad.
2) Left turn signal indicator light turns on with brakes
3) Wipers not hooked up right.
Otherwise ok. I figured there would be some kinks to work out.
For wipers
Are you using a kit like in the first pic or just a switch like in the second pic ?
just trying to make sure.
switch in the second pic with the stock cruiser wiper motor.
I've got some bugs to work out in the harness. the Alt isn't chargeing, right turn signal comes on with the brakes and speedo does not work.
