Extended Travel Issues
Eagle, ID
Long Travel Shock Issues
I have my new shocks and am working on new shock mounts. So far i have 2 issues. one in front and one in rear.
Front- The line of wire that runs to the ABS indicator on the knuckle is maxed out. I have unhooked from the stock control arms (wich are gone and replaced with new ones) and they are still too short. My question is how would you lengthen them or would you. How many of you have disconected your ABS anyways? is it really as easy as splicing in longer wire? any ideas or input would be great.
Rear- My ebrake cable gets stretched and pulls when i have lots of droop. i have un hooked the hoop that it runs through and it just kinda hangs. how can i lengthen or adjust this more? any one do other special mounting to keep from pulling on it too hard.
Should have pics over the weekend. I am putting new 5150 Bilstiens (14inch travel) under all for corners. the front is getting hoops and the rear is going to be mounted in the cab behind the middle row seat.
roughly following the woodmaster ala https://forum.ih8mud.com/showthread.php?t=18130
Pics and thread with the whole build up will be forthcoming shortly.
I run w/o my abs... don't care much for it on road in the snow/ice. Maybe you could move the sensor wires and mount it to run down along the brake lines?
My truck is only at the lower hoop mod stage.
Can't wait for pics... sounds excellent!
Sicko,
The rear hoop thing sounds like what Christo mentioned awhile back. I'd be interested to see what he or Robbie mentions about the ABS. Guess my truck isn't big enough any more :D as I have no issues with the ABS.
hmmm. i was off for most of the summer. what was christo thinking of doing? any pics or links? should be finished up over the weekend.
Brian, thanks for the heads up on the ABS. I am leaning towards just going no abs up front but i still have ish in the rear
Actually he mentioned it to me mid-spring (no pun intended :D ) as I was planning on fitting bigger tires. Since then I have gone in yet another direction :D
what i know of the sheilded cable is i cut one and tried to soilder it back together and it still did not work. i do not know if some sort of special cable splice is around, but might be. this is shielded cable similar to coax cable but not the same. mabe the thing to do is find a junker and get the cable and see if you can splice it and then sheild it so the computer will read the hall effect sensor correctly. good luck, robbie
What made you think your truck was ever big? :D J/K
Robbie,
thanks for the input. What would you think if i just ran a new (longer) cable and didnt worry about the sensor. do you think that would work? I am not super worrried about the sensor. Have ya'll done anything at the shop to allow the rear end to droop more with out your e-brake cable turning into a limiting strap?
I ditched the ABS. Removed the sensors and cut 1/2" of them so that I did not have to remove then when fixing the broken birfields. Pulled the light on the dash.
On the rear I have the e-brake cable running without the center support. No problems with it at all. I believe I tied it up somewhere with a zip tie.
I have a symilar hoop on the rear, but on the front I just did a U channel tapered piece and welded it over the existing shock tower. You can see the top here http://www.sleeoffroad.com/technical/warwagon/images/web_publish/220.jpg and http://www.sleeoffroad.com/technical/warwagon/images/web_publish/221.jpg
The 2" body lift and using a eye style bolt gave me about 4" more
The rear of the truck droops about as much as it could without a limiting strap. Any more and the rearsteer will make you go in circles. Are you doing longer rear arms?
I have new rear control arms and they are a bit longer..... as well as pre bent up as to not have to ramp them as much. (will look for pics)
Thanks for you input. sounds like the ABS is going by the wayside and i can just lose the center support on the e-brake. easy fixes.
the rear hoop is definetly easier to figure out than the front. I like what you did on the front and am leaning towards doing that as well an would work s that is the style mount that those shocks have.
Sickboy Here is another approach on the way to fit 14” on an 80. The lower mount was relocated and the top is as shown. The results are 6” of compression and 8” of drop. The rear was done the same way but 12” travel was used on the rear to keep the springs from coming unseated on full drop. Depending on your rear spring set-up you may be able to run 14” on the rear without the unseating issue.
Phil
Phil,
Which Bills are you running?
NW-sickboy said:
lets see the bottom mount on the rear axle? seems like it would sit way down there. how do you like the 7100's..... ????
7100's is the only shock you will ever need for the life of your Cruiser. Completely rebuildable, adjustable valving, adjustable nitrogen presure, and seperate compression and rebound tuning.
Phil
Thanks for the pics dude. What are the specs for your particular shocks? psi and valving. Also, were you able to get them for less than $180/each? if so, where? Also, what's the p/n for your application? I'm just going to file this info for the "future"!
thanks.
Ali
Phil,
Hey thanks a ton for your pics and input...... your front mock up is basically what i (fab shop) worked out .... the bottome mounts are a little below the axle but are beeffy and boxed in soo i am stoked how the front turnd out....
I went back and forth on the rear ..... thinking of lowereing the bottome or doing a hoop in the rear... I really couldnt push myself to lower the mount so we did the hoop.. it doesnt stick up high and doesnt interfere with the seats.... i just need to paint the hoop, cut the carpet, and fab up some rubber covers to seal off the floor around the shocks.
All in all i am EXTREMELY pleased with this. I finally feel like its all coming together. I am running it this weekend and will have pics after i get my front axle back together.... thanks again for your input phill.
As far as splicing in the ABS wiring I did do that successfully on my rear setup. I had melted a host of wires right in front of the gas tank (brilliant move on my part). This included all rear locker wires, and the rear ABS sensors. What I did was get shielded wire from Home Depot, I only needed 2-conductor wire but IIRC I got 6-conductor since that's all they had, I got the shielded with the largest size of each conductor. I then opened everything up, the factory shielding was crap, a wire braid that was falling apart, so had to be very careful there. The new wire had a tinfoil-ish shield, so I got enough of that accessable to cover everything I was doing. I then soldered the two actual conductors with their new wire, put shrink tubing over each one, shrunk all those, then while keeping as much of the original shielding as I could, arranged the new shielding so it all touched as good as I could, the key there is to make sure there is a good electrical connection from one shield to the other, ideally you could solder the shield but my factory stuff was in no shape for that. I then slid shrink tubing over all of it, and another layer over it also, shrunk it all tight and has worked perfect for about a year now.
If doing this, make sure you plan what you're doing, remember all shrink tubing has to go on the wires BEFORE you solder them together, I only made that mistake a few dozen times. It's definetly do-able though. If you could find a marine-grade shielded wire definetly use that. I didn't have time to look for that, I used marine grade wire for all my other non-shielded splices (rear locker stuff), marine wire is good stuff.
Edit: It appears West Marine has stuff that would work http://www.westmarine.com/webapp/wc...001&langId=-1&catalogId=10001&productId=28562 It claims it's shielded, 18-gauge is much thicker than you need however, but would probably work.
Good luck...
Mark Brodis
