Extended Brake Lines/ Shackle reversal
Discussion in '60-Series Wagons' started by alpendubber, Aug 23, 2006.
  1. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    Does anyone know where I can get some extended brake lines other than MAF?
    Also, for the those who have done the shackle reversal. I have heard two different methods of mounting(MAF kit via ebay). First method is leaving the springs in the same direction as stock and just installing the kit. Second, is to actually reverse the spring entirely and bolt up.
    Any suggetions would be much appreciated.
  2. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    23,093
    1,231
    Apr 4, 2003
    Panamá
    when I install my SR kit from MAF .. I never flip the spring pack .. I instaill in the same traditional way
  3. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    Tapage, did you have driveline probs? I read some other threads, and it seems like some have problems and some do not. I saw the pic of your rig before SOA. Looks Good
  4. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
  5. S&S1stCruzer
    S&S1stCruzer
    1,134
    1
    Mar 29, 2006
    AZ
    I bought the MAF S/r kit springs and all, and installed them with wrap to the rear per MAF instructions but it wouldn't be the first time I've be miss lead.
    Give them call or Give Kurt at Cruiseroutfitters a call and see what he says and let the rest of know.
  6. Tapage
    23,093
    1,231
    Apr 4, 2003
    Panamá
    Thanks dude ..
    No I have no issues with OME 2.5 Heavy and SR kit in my drivetrain. I need no drive shaft mods with this setup.
  7. mrsvle
    mrsvle
    183
    1
    Jan 8, 2006
    Tucson, AZ
    After I installed my IronMan Suspension I upgraded my brake lines with extended braided stainless steel lines from Specter Off-Road. I'll try to remember to snap a picture of these tonight. I'll also snap some pics of the shackles, etc, since it appears several people are installing these kits and its not always clear the orientation of the shackles or military wrap. Matt
  8. exrsa1
    exrsa1
    1,007
    Oct 7, 2003
    Kansas City, MO
    There was a company that sold extension brake lines. Meaning that you do not replace the existing one, but undo it at the axle connection, add this extension, then attach to axle side again. I have these on my Fj40 after I did the 4" lift. Anyone know who sold those? It was way cheaper, although I am not sure if it was DOT approved.
    On the MAF shackle reversal, on the 40, the springs switched around, in other words the side that was attached to the shackle, is still connected to the shackle, just on the back side.
  9. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    mrsvle,
    I have already installed the springs weeks ago, they ride great after giving them a hard break in. I was originally asking about the shackle reversal. Thanks for the info though.
    exrsa1,
    That is my understanding, that the front of the spring now will move with the shackle to the rear. Did you take a look at the pirate link I posted above....This set-up is what I am going with. Ironman 2.5" with old style MAF SR. He has the springs in the normal direction, do you think he has done it wrong?
    Just talked with Freddy at MAF, he said that the spring should be reversed, putting the military wrap end in the front.
  10. Cruzerman
    Cruzerman
    1,975
    356
    Apr 23, 2005
    Oregon
  11. Dirtgypsy
    Dirtgypsy
    2,403
    52
    May 27, 2006
    Dundee, Oregon
    I have been running my SR from MAF for about 2 months now. I ran my military wrap to the front per MAF recomendations. Also correct me if I am wrong but it is my understanding that the non military wrap end is designed to flex a bit with the shackle when the axle is articulating. Same as the rear.
    clint
  12. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    clint,
    I agree, I am going to go ahead and mount mine the same as yours. What springs are you running?
  13. exrsa1
    exrsa1
    1,007
    Oct 7, 2003
    Kansas City, MO
    Here's what I understood of the MAF reversal kit when I did it on the 40. Due to the front slant design, the axle would move back from it's original position, if you kept the springs facing the same way. By flipping the spring, the center point of the axle moves back very close to where it was before. I can't see that thread on pirate for some reason.
    The shackle reversal also adds 1.5 inches of lift, so in a 4" lift you would use 2.5 inch springs for the front and 4" for the back, to get a nice even lift. With the Ironman sitting somewhat butt high, the SR may just even it out.
    Anyways, good luck, and post some pics!
  14. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    Thanks for the info. I will take some pics before and after. It may be a couple of weeks.
  15. exrsa1
    exrsa1
    1,007
    Oct 7, 2003
    Kansas City, MO
    Alpen, I was talking to man-a-Fre today and whilst on the phone asked about the SR for 60's. According to him, on the 55 and 60, the spring is not flipped around like on the 40.
  16. lcwrench
    lcwrench
    26
    Aug 8, 2005
    The reason you would flip the spring on FJ40's is that there is a short leg and a long leg from the eye to the center pin and you want the long flexible leg at the shackle end and the shorter stiffer leg at the fixed pin. FJ60 springs are symetrical (or should be depending on manufacturer) so the only consideration is the military wrap, which is normally at the fixed pin, not the shackle.
  17. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    So, this has become really confusing. If the springs according to MAF should not be reversed then how does the Military wrap end up in the front?
  18. Shinichi
    Shinichi
    569
    Mar 28, 2006
    Basalt, Co
    I am getting ready to do the same kit. Got to get a look at yours.
  19. lcwrench
    lcwrench
    26
    Aug 8, 2005
    Not trying to confuse you. What I am saying is that if you don't put the military wrap at the fixed pin, it's really not critical like it would be on a FJ40. I personally did put the military wrap on the fixed pin on my 60 because this is where it normally is and IMHO where it should be. I'll talk to Freddie and make sure he understands this a little better. Sorry for the confusion
  20. alpendubber
    alpendubber
    788
    10
    Jun 13, 2006
    Idaho
    No problem, I will go ahead and mount them the way you suggest. I am using a friends bay at the Audi shop he works at, it's like a one shot deal so I wanted to do it right the first go around. Thanks for the info.
