- Location
- United States
Rear 80 series lower control arms, +11mm vs stock. Rubber bushings, just like stock, at both ends. Similar in build to the stock arms. From what I can tell they are the same dimensions, just longer. Used to correct rear DS pinion angles to allow use of a stock shaft with approx 4" lift.
Used for only 30 mi.
These are from Mark's 4wd in AUS. The brand is "Road Safe.". They are very reasonable from Mark's, but shipping from Aus is about the same cost as the arms themselves.
$130 shipped to you, $100 picked up in Flagstaff, AZ.
