I'm a noob looking to put taller tires on my '55 - and wanted to at least consider a lift before I buy 33"s. The thing is, with all of the code and jargon being thrown around, I'm having a tough time discerning the lift options out there.
Basically, I know nothing about lifts and would love to know:
how much they cost
what's the best way
what's the cheapest way
can it be done yourself, if not, how much at a shop, etc.
This is for a daily driver- looking for more speed out of my 4-spd tranny and F2 engine
how much they cost
what's the best way
As stated above the easy way is shackles. They are unattractive they give body roll they change your caster your pinion angle etc. And if you are shackled in the front they are rock catchers. (sorry guys my opinion) So you could go with a cheap body lift. (80 dollars) Functionally probably one of the best ways due to you only lift the weight of your body. You do not mess with steering geometry, BUT i have to say it ....... Looks terrible. All of the above you can do yourself with some help from this site and tools. Another option is spring over but you get into a lot of negative benefits that take extensive work to correct. (the method i have chose on several vehicles in the past) Last but not least you have the option of new springs or cheap you could use add aleafs the add a leafs will make your ride stiff.... The new springs would be the way for you to go (my opinion again) since they come with good instructions etc. and it seams you may not have welders, torches, etc. And you will have a nice ride and still should drive great. Just trying to help good luck
