Exide Orbital battery. 80 feels more....lively?
Shahram
I ain't got herpes no more.
TEHRANGELES
Hey kids. Battery died over the weekend. Jumped it, ran fine. Once I got home, couldn't start it again. Voltage meter, which I assume runs off of the alternator, said that the battery was getting juice, so I had to assume the alternator was okay. Anyhoo, looked around for an Optima Red Top to fit my needs. Costco was fresh out, and the monkey'tards at Pep Boys looked at me like I was from Mars and said, "Duh, Optimas don't go in Land Cruisers". I normally don't really step foot into Pep Boys, but I happened to have a gift card, so save your derision. I looked on here and lots of folks recommended the Exide Orbital battery from Napa. I purchased one of those, installed it, and some funny things started happening.
First crank of the engine, idle was up around 2000 RPMs. That lasted a couple of seconds, then it came down. Idle is normal now, but other things are just...different. Bear with me here, but I can't help notice that the truck is just a little more lively. The interior and dash lights are a little brighter, the window regulators a little more responsive, the headlights a little more....peppy? I've had the 80 since March, and I always assumed the dim lights and slow windows and long starts were a product of ten years of use. Now I realize the battery was probably weak for a long time.
Oh, and the Check Engine Light / P0401 code that I've been getting? Gone! Bam! I'm sure it'll come back, but what the hell, I'm enjoying its absence.
RPM's were high and the code is gone because you reset/cleared the computer when you disconected the battery, it needs to re-learn......
Put the pipe or bottle down and back slowly away. :D
On a serious note that is interesting, was your prior bat an optima?
However I see pimp already beat me to the punch on the idle and code.
To bad you didn't have a reading on the prior bat when it was still so so.
Did you have any issues with the center mounted posts on the Exide Orbital? I'm thinking about purchasing one for my 97 LX but there's currently not enough slack in the positive and negative cables to reach the posts on the Orbital. I'll need to snip some tie backs and even then it will be tight.
Okay, good to read this terrific thread ... I seriously had this same happy thing happen many months ago when I was replacing my Toyota TruStart with an Orbital from Napa. I too seemed to sense more uumph in my rig and in my rig's accessories. I did not say anything at all as I was afraid people would think me crazy but since Sharam stated it, and since we all already accept him as crazy, what the hell, I'll verify sensing the same thing! :D
Strangest thing though was that the toyota trustart was replaced proactively and still works well so it was not what you would expect with a bad battery causing the alternator to work harder and therefore causing the engine to work harder to power the alternator. Still when swapping with the toyota trustart, that slight sensation of more uumph is still missing. Very strange thing. :confused:
you guys wear Aluminum foil hats too, right? for more ooomph? :D
shahram and turbocruiser...
you guys are nuts...
tired battery vs. new battery
dim lights vs. bright lights
seems natural to me.
I wouldn't think it would make a difference once the rig's running and you get your power from the alternator...or am I incorrect in the assumption that juice comes from the alt. not the batt. when it's running.
CEL will come back on if there's a problem...
noooo maaaan you got it wrong, the Aluminum foil hats, while worn regularly, are not for more ooomph, they are to deflect the barium brainwash dust the damn fawking democrats scatter through the sky with "retired" air america airplanes! :D
ohh gumby obviously lost his hat long ago! :D :flipoff2: :D
To lengthen your terminal(s) a bit, go to Sears and get their quick disconnect battery terminal. It's a knurled knob affair that allows you to physically disconnect the battery in seconds such as if a starter sticks, or you want to disable your rig for theft reasons, or will leave it for a long time and want to thwart some minor drain giving you a flat battery. What it also does is lengthen the terminal reach by several inches so you can use center posts. Cost less than $7 I think.
When we leave it for a month it's nice to reconnect and have power. I bought it one day at Sears, frustrated they couldn't fit a hulking size in the tray because of the wire layout "Hey, look at this - let's install one and the battery will fit, eh?" Party in the install shop...
DougM
DougM
walmart has one too. got it after reading the fire stories here.... :eek:
Happend to me too. I think, like pointed out above, the computer is at a fresh start. As soon as it starts sensing O2 sensors and knock sensors, it will begin to run sluggish as usual again. Just give it time.
Arya Ebrahimi said:
:eek: Holy crap, he made a joke, and it was kinda funny! :D
eh! I know lotsa funny jokes...!
here is one:
"Why did your cousin cross the road...?" :D
FWIW, I recently bought an Orbital battery, then got into a discussion on batteries. Did some research, and the Optima specs are slightly higher than those for the Exide model. Both are very good batteries though, with pretty much the same design. For equal money, I'll go with the Optima next time.
-Spike
Uh...okay, so, the center-mounted posts caused no problems. I just yanked on the cables REAL HARD and....all right, I'm kidding. It connected right up, no issues. If it had been a centimeter farther, I may have had a problem, but as it is, it was fine.
I know that it may not make sense to some, but I've been driving this Cruiser for the last 6 months and more than 10k miles, and the thing just feels peppier. What, it's been four, five days later, and still no P0401 code. Had it smogged today--passed, even with gaping hole in exhaust manifold and the EGR issues. Got it registered--I don't know why, and I don't know how, but my registration fees were WAAAAAAY lower than I had thought they'd be. I'm telling you guys--this battery went into my EGR and cleaned it out. Then it told the database at the DMV to charge me less. And the big-booty DMV hottie was vibin' me, man! She wanted my digits in her back pocket, and I ain't talkin' about my phone number!
Telepathy? Maybe. I dunno. I'm just saying the thing's got powers beyond our comprehension.
Seriously, though. Is it even remotely possible that a weak battery would cause the diagnostic system to throw a "false" code? C'mon, computer guys--do your thing. Dance, monkeys! Dance!
