Exhaust routing over x member?
hello everyone have a question about exhaust pipe routing, have a downey header (off an fj 60) and downey 2.5" exhaust pipe kit arived yesterday
tryed to install kit problem / question is this pipe bolts up to flange at header travels above skid plate then seems to route above ist tubelar x member past transmission i am doing frame off and cannot get to body to see if it will fit, (buried under 8 feet of snow)seems to me pipe should route under both tubelar x members also when pipe exits past rear tank(confer aftermarket) there isnt much clearence 1.5"
and pipe hangs down more than i like when i pull it up pipe at 1st x member is 2" above frame, any one try to use downeys tail pipe / muffler setups ,might have to go to muffler shop after all and have re bent , might try to call downey on monday to see wwhat up, any input would be apricated :cheers: almost forgot its a 78/40
"there is no bussiness like snow bussiness"
OK drove down the hill to a friends crusier looked at his setup 77/40 it does indeed route over 1st x member and under 2nd also pulled up pic at maf and it showed same on their system thanks ,
