yes, you are right and i sit corrected, both are related as in they both react to teh same source but that is all.Greg_B said:EGT and water temp are totally related, in that they both come from the same source (containment of the combustion process).
They may react different at different times, however they are related. Run too high EGT's for too long and it will reflect in stressing the coolant system (amoung other things).
For some reading on EGT's, impact and other thoughts go here:
http://www.bankspower.com/Tech_whyegt.cfm
http://www.steves.co.za/Engine_Protection_Units_1.html
hth's
gb
you can run low EGTs (for example 900F) and still boil over on a long hill. you can run low water temps but be over 1200F EGTs.
i have done lots of testing of this with the various pyros i have installed on different engines. the 2 readings are normally unrelated but that being said, a poorer cooling system can lead to higher EGTs over all.
cheers
