Read through a ton of caster posts but couldn't find a similar experience. Just had an OME Medium Lift kit installed on a '97 LX450. Included the ARB yellow caster bushings. First impressions were positive though I did notice a little twitchy behavior in the steering as well as a drone or a very slight vibration, assuming dive shaft, starting at about 35mph.
Took the rig to have the alignment checked and the casters readings were -2.0 and -3.1 respectively. No where near the target of positive 3 degrees. I called the install shop and taking the truck back early next week for an inspection. They swear it was done correctly because they used the template to install the bushings. Still seems we have gone the wrong direction of correction as we are now at approximately negative 3 degrees. I'm no suspension expert and trying to become more knowledgable reading various posts here.
What should I look for when visually inspecting the caster bushings under the truck to see if they are installed correctly? Thanks for any input!
