3b - excess black smoke issues
hey guys..
trying to work through some issues to sort an excessive black smoke under load issue i've had with this 3b since I purchased it.
things i have done to date:
- swapped over injectors for reco'd injectors
- replaced governor diaphragm (found two small holes/rips in the existing one)
this was done today and i took it for a test drive tonight.. it still had a fair bit of black smoke under load but not nearly as much as it did before..
The only other outstanding issue i can think of is the fact that the edic appears to be sticking in the overfuel/start position..
i know the edic has 3 positions, and overfuels for startup.. i have noticed that it doesnt appear to be returning to the "drive" position after starting.. if the edic motor is having issues returning the rod to the drive position is there anything else i can do other than replacing the edic (i have a spare on the other 3b)..
Ive got the factory manual here.. so I'll be checking it out closer tomorrow (ie, the marks it mentions in the manual for the "drive" position).. but what do you guys think? could this be contributing to those symptoms?
normal driving doesn't produce excessive smoke.. only when you are working the engine hard.. I dont know of the fuel has been turned up at all before I received it (no seal wires on the injector pump that i can see)..
I'm running out of things to check/fix to resolve this excessive smoke issue.. so any ideas/thoughts are appreciated!
hey guys..
