Error Code 41 Throttle position sensor signal and cruise control (1 Viewer)
FRANCE
Hi,
I have two problems on my 1995 HDJ80 24s with 1HD-FT,
My Cruise Control is over since december and when I checked the engine it gave me a code 41; "Throttle Position Sensor Signal",
Do you think there is a link between this two problems (is the TPS used by the CC?)
I the TPS an usual problem on our 80? Did you ever change the tps on your 80?
I've search on many posts on the web, but can't find any solutions:confused:
HELP:bang:
I have fault code 41 as continuous current in the open motor circuit.
The information I have suggests the Ecu is no good. If you post you email I will try and scan and email a pdf of the test procedures.
:confused:
Looks like Throttle Position Sensor (TPS) to me:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
As for the cruise control; it has its own diagnostics system and its own codes you can pull.
Curtis
P.S. Welcome phin1 :)
Well, actually I guess I honestly don't know for the diesels.
Sorry if I've mucked up the thread, but 41 is definitely an OBD1 diagnostics code.
Curtis
I have a 97 (which is essentially the same) and the procedure I have worked for me My truck gives different codes to the obd. I would post the information some where If I knew how or where.
Hi alex the method for checking is the same, only the meanings change,
1 Was it the cruse light that flashed out the code.
2 Is you truck an auto and are the gearchanges still ok.
3 Your Tps should be 3 wire 5v across 2 wires (note the -ve) and approx 4 volt at closed and 1 volt open across the -ve and the other wire
4 the cruse control doesn't use the Tps, It uses the speed sensor
I have the complete test and diagnose if you are interested
ok for your document, I'll have a look,
alexisvincent1 (at) hotmail (dot) com
thank's
Alexis
