Erratic idle 22RE
Discussion in 'OH- The Buckeye Birfield Syndicate' started by Toylookn, Feb 23, 2007.
  1. Toylookn
    Toylookn
    39
    Jan 31, 2007
    So I finally get the frame rails repaired and the gas gauge fixed and my beater is back on the road. I have an erratic idle problem. Since this is my first foray into Toyotas, what should I replace or check out first? Are there any other issues with the 22 RE I should expect to encouter?
    Thanks
    BA
  2. JuttyShabango
    JuttyShabango Checkers R Wreckers SILVER Star
    1,373
    May 11, 2005
    How's the timing chain? MAF sensor?
    22R platform is pretty simple. Add the E and it' gets a little more complicated.
  3. trailyota
    trailyota
    34
    Oct 25, 2006
    Mine idles hi every once and a wile found out the throtle was hanging up a little. I wd40'ed the spring and it was fixed.
  4. JuttyShabango
    1,373
    May 11, 2005
    That's cause your foot is pegged to the floor..:flipoff2:
  5. Toylookn
    Toylookn
    39
    Jan 31, 2007
    Is the 22RE notorious for stretching timing Chains? This is the second time I have heard this.
    BA
  6. JuttyShabango
    1,373
    May 11, 2005
    Not anymore than any other engine that has them.
  7. BUCKEYE4X4
    BUCKEYE4X4
    466
    Apr 23, 2005
    Columbus, Ohio
    TPS, ICV(?), fuel delivery, old dirty injectors
    the service manuals have good trouble shooting.
    timing is easy to check :D
    is it loping (sp?) up..down..up, or eratic like fire fire misfire?
    try to determine if it is spark related.:rolleyes:
  8. Toylookn
    Toylookn
    39
    Jan 31, 2007
    Runs smooth, no miss. Just jumping up and down. Seems to get better as it warms up. It has to be a sensor of some sort. I need to get a service manual for this thing.
    BA
  9. JuttyShabango
    1,373
    May 11, 2005
    O2 sensor or the MAF..IMO.
