HungryMedic
That doesn't look too hard... What could go wrong?
Updated 01.24.15
Alrighty so I acquired a new rig! I've been looking for a while for the best vehicle that suited my family for a reliable utilitarian type vehicle.
I decided to go with an 80 for the fact that I could put plenty of gear in and on it while still having the room for my family. Even more so since we decided to grow the family with baby number 2(ITS A GIRL!) due In August 2015.
Haley was pissed at first but... Easton is in love with it and Haley has up and taken it out for drives at least once weekly now so... No more dog house!
I was trying to get it ready to show and introduce at the EHEO meet and greet but since I wasn't able to attend, here it is.
Without further adieu...
My new to me 1993 Toyota FZJ80
Acquired 10.20.14
-217k miles
-factory front, rear, w/CDL mod
List of parts (via PO)
Odo- 217,023
Suspension and tires:
-OME 2.5” Suspension lift
(heavy/heavy) shocks, springs, steering stabilizer
-Metal Tech 1.5” front coil spacer
-Metal Tech 2” front swaybar link drop brackets (aluminum)
-315/75/16 Cordovan Mud Claw tires
Audio:
-Pioneer Bluetooth digital media receiver
-front and rear 5 ¼” door speakers
Misc:
-rear lift gate shocks
-CDL switch mod
-4 factory Toyota center caps
-speed sensor o-ring replaced
-a/c idler pulley, a/c charge
-A/C converted to R134
Body:
-removed fender flares
-removed mud flaps
-removed running boards
-removed pin-stripe
Interior:
-refinished driver and passenger seat bottoms and sides
Recovery and armor:
-Metal Tech front tube bumper
-Badlands 12k with wireless remote
Power train:
-Valve cover gasket @216,323
-Spark plug wire gaskets
-Spark plugs
-Oil & filter change
-partial EGR delete
-catalytic converter delete
Mostly tinkering for now...
First day of work!
10.28.14
Odo-217,345
-optima yellow top main batt
-greased driveshaft and u joints
-all new fuses
-fuel treatment #1
-no more wood grain!
-front twin cup holders from Brad's 3D
11.5.14
-replaced passenger mirror with depo
-new Fram fuel filter
-installed RAM mount and iPad mini
-new front windshield wipers
-greased driver and pass knuckles
-clean clean clean clean
11.16.14
-led bulbs in every spot imaginable
(Map, glove box, all three domes, side markers, front marker, reverse, license plate, and tail lights)
-found out my dome lights have electrical gremlins(fixed)
-aluminum tailgate handle
11.19.14
-new door jamb switches installed x4
-carbon fiber interior accent
-new wired winch control
11.20.14
-replaced gauge back lighting bulbs (194LL)
-replaced rear wiper
-cleaning and de-greasing
-installed license plate
12.05.14
-fixed fast blinker(wrong bulbs...I'm dumb)
-installed emergency multi-tools x3
-mounted fire extinguisher
-re-spooled winch line
-steering wheel cover
-gummi Pflege'd all door seals
12.15.14
Current Odo- 218,032
-installed YodaTEQ pass side antenna mount
-snorkel install
01.21.15
-Fixed dome light issue
-Pulled winch cable to prep for winch rebuild
02.22.15
ODO-219,318
-replaced cap, gasket, rotor, & wires
-vent hoses
-coolant hoses
-heater hoses
-replaced both temp senders
-replaced thermostat
-coolant and heater flush
-filled with toyota red
-topped her off on all fluids
03.10.15
O2 sensors
Cleaned throttle body
03.18.15
Intake hoses
PCV valve
Grommet
06/15
Badlands 12k W/all goodies
VAFM
08.20.15
Greasing and TLC
Adjusted throttle
Filled fluids
Pending:
AJIK PHH kit #2
Ignition switch solenoid
Front Locker position switch
front and rear end rebuild
Transfer case flush
Tranny flush
Oil change
New front pass fender
Battery wires/clamps
What I want/should/need to do next!
(In NO order what-so-ever...)
Interior:
-dash and rear speakers
-subwoofer and amp
-replace window tint
-power door locks don’t work
-shampoo carpet and headliner
-new rear seat leather covers
-floor mats for middle seat and rear deck
-sliding drawers
-shifter knobs w/ OD button(obtained)
-Car seat anchors for the munchkin
Suspension and axles:
-ALIGNMENT
-bump-stops
-grease zerks
-re-route diff breathers
-Dusier axle and knuckle rebuild
-front and rear diff fluid change
-brake pads and maybe rotors
-SS extended brake lines
-re-gear 4.88's
-long fields
Recovery:
-snatch block
-snatch straps
-tow straps
-shackles
-2 four ft sections of 3/8 cable
-synthetic winch rope
Power train and transfer case
-power steering hose and pump leaks
-oil change and filter
-transfer and tranny flush and drain
-new fan clutch
-seal air box
-Pesky Heater hose(I'm lazy)
-new belts
-K&N air filter
-marlin crawler gear reduction
-new injectors
Exterior and body protection:
-sand and patch flare holes
-pull dents
-Monstaliner (still picking a color)
-sliders & rear duel swing out bumper
-window trim
-window seals and weather stripping
-door seals and weather stripping
-sun roof seal and weather stripping
-beef Skids
-install hood Vents
Lighting and switches:
-Sylvania zXe headlight bulbs
-led rock lights
-led roof bar
-led fogs
-OTWATTW switches
-Slee headlight harness
Battery and equipment power:
-duel batteries
-replace clamps
-heavy duty alternator
-new battery cables
-blue sea fuse block
-solar trickle charger
Storage and Misc.
-on board air
-trasharoo
-drop in roof rack
-Rear slide out w/ equipment rack and boot cubby
-spare tire and rim with mount
Ill post tons of useless info and pictures and I promise I'll edit this main post as I do things!
Affectionately called Hulk the Fun Truck by Easton.
Acquired 10.20.14
-217k miles
Odo- 217,023
Audio:
Misc:
-CDL switch mod
Body:
-removed mud flaps
-removed pin-stripe
Interior:
Recovery and armor:
Power train:
-Spark plugs
-partial EGR delete
First day of work!
10.28.14
Odo-217,345
-all new fuses
-fuel treatment #1
11.5.14
11.16.14
11.19.14
11.20.14
12.05.14
12.15.14
-snorkel install
01.21.15
02.22.15
ODO-219,318
-vent hoses
-coolant hoses
-heater hoses
03.10.15
O2 sensors
03.18.15
Intake hoses
PCV valve
Grommet
06/15
VAFM
08.20.15
Greasing and TLC
Adjusted throttle
Filled fluids
Pending:
AJIK PHH kit #2
Transfer case flush
Tranny flush
Oil change
Interior:
-subwoofer and amp
-sliding drawers
-ALIGNMENT
-bump-stops
-grease zerks
-re-gear 4.88's
-long fields
Recovery:
-snatch block
-snatch straps
-tow straps
-shackles
-new fan clutch
-seal air box
-new belts
-K&N air filter
-new injectors
-pull dents
-window trim
-beef Skids
-install hood Vents
-led rock lights
-led roof bar
-led fogs
-OTWATTW switches
-duel batteries
-replace clamps
-new battery cables
Storage and Misc.
-on board air
-trasharoo
-drop in roof rack
