I picked this truck up 5 years ago in Wisconsin - rust free from AZ, for $2,200.
Slowly bringing it back from neglect
black interior
black carpet
dynamat
door panels
lots of wiring
lined cab
95 4runner bucket seats
V6 brake booster
A1 Cardone Ultra premium V6 calipers
OEM wheel bearings and seals
EBC blank rotors
EBC green stuff pads
O'reilly CVs
OEM power steering installed
front main seal
windshield
marlin shifter cup
rebuilt hubs
valve lash
plugs
fluids
OEM thermostat
OEM radiator cap
OEM clutch master cyl
OEM clutch slave cyl
side mirror
rear pinion seal
frame paint
Fall 2018
Bilstein shocks
LCE Header
Homemade 2.25" stainless exhaust
Magnaflow 11245 muffler
Bosch o2 sensor
Viair OBA 400C compressor 2.5 gal tank
Yukon rear zip locker
31x10.5 Cooper STT Pro
Spring 2019
4.7 marlin competition gears
Aisin pressure plate
Luk flywheel
Secco clutch
Pilot bearing
Clutch release bearing
Main seal
OEM distributor cap
OEM distributor rotor
Honda Odyssey washer spray nozzles
WIX fuel filter
Summer 2019
Parking brake cable
Crank arms
Rear wheel bearings and seals
Drums
Shoes
Hardware
Summer 2021
All new ball joints, tie rods, steering components
33s from my 80 series
Spring, Summer, Fall, Winter 2022, Spring, Summer 2023
Engine build:
Bearings - King 0.030 under. CR4129AM0.75, 506AM0.25, TW 234AM
Rods - Eagle forged H beam CRS5819T3D
Pistons - 22RE Performance 4032 forged - 0.020 over
Rings - Hastings - gapped to 0.027/0.028
Head Gasket - Cometic MLS C14086-040
Head - 22RE Performance Stage 4 CNC port machined
Cam - 22RE Performance Turbo cam
Oil pump - Aisin OPT054
Water pump - NPW PT T-67
Timing Chain - OSK 22RE Perf
Timing Cover - 22RE Perf
Head bolts - ARP 203-4201
Freeze plugs - 22RE Perf
Dipstick - OEM 1530135020, tube 1145235010
Plug gallery kit - 22RE Perf
IAC hoses - 2223-35010, 2223-435010
Throttle body hoses - 16264-35012, 16267-35010, 16281-35010
Oil pressure sending unit - 83520-55011
Coolant temp gauge - 83420-20020
Coolant temp ECU - 89422-12010
Rocker arms - 13801-35010
Rocker nut and screw - 90179-08049, 90913-05019
Packing, Dust proof - 1912715021
Distributor Rotor - 19102-73021
Distributor Cap - 19101-35180
Ignition Coil -
Spark Plug Wire Set - 9091929055
Cooling
Hoses - Dayco 71262 upper. Gates 21033 lower
Radiator - CSF 2306
Thermostat - 90916-03078
Fan - SPAL 16" puller
ECU - Megasquirt PNP Gen 2
Turbo - Garrett GBC22-350 44mm
BOV - Tial Q 50mm 11psi spring
Injectors - Five-0 Black Ops 550cc high impedence
Fuel Pump - Walbro F90000274
Fuel pressure regulator - Aeromotive 13129
Exh manifold - home made
CAC - Volkswagen Passat 2000 1.8T by Majesty
Brackets - powder coated
Alternator - Jaguar XJ6 Denso 2100406
2013
2023
2024
black interior
black carpet
dynamat
door panels
lots of wiring
lined cab
V6 brake booster
EBC blank rotors
O'reilly CVs
front main seal
windshield
marlin shifter cup
rebuilt hubs
valve lash
plugs
fluids
OEM thermostat
OEM radiator cap
side mirror
rear pinion seal
frame paint
Fall 2018
Bilstein shocks
LCE Header
Bosch o2 sensor
Spring 2019
Luk flywheel
Secco clutch
Pilot bearing
Main seal
OEM distributor cap
WIX fuel filter
Summer 2019
Parking brake cable
Crank arms
Drums
Shoes
Hardware
Summer 2021
Engine build:
Ignition Coil -
Cooling
Radiator - CSF 2306
2013
2023
2024
