I shipped it out UPS today, should be there monday according to the lady behind the counter.
I included the filled out form, the ECU and the engines wiring harness. I will be running a manual and just want the simplest system I can have on it.
I still have to track down the correct drive by wire pedal for the engine, ignition wiring, OBD2 wiring, Fuel pump wiring(?), Check engine light wiring, do you know off hand if I will have to run a speed sensor?
Just let me know what you are able to do and I will figure out the rest.
Thanks again!
Thanks again!
