Engine Temperature Question
i did a search but no answers to my questions...figured i'd throw this out for consideration.
My new 1889 FJ62 has a new radiator and a new water pump and thermostat. The system does a GREAT job of cooling the 3FE. I'm concerned ,though, that it does TOO good a job.
My observations:
1. The temperature guage. Now I know that the stock guages are notoriously vague. BUT mine almost never gets above the first line. Something i have never seen. And i say almost never because I HAVE seen it climb up to about 1/3 on steep hills when really pushing. So it seems to be reading temp.
2. Black carbon on the exhaust. The tailpipe has excessive black carbon on the end...Again, something i don't think i have ever seen. I'm assuming that it might because the motor is running too cool.
What ,if any, are the symptoms and or problems of a motor running too cool.
Could it be that my thermostat is stuck open?
I'm curious to see what the MUD crew has to say about this.
Thanks in advance
:beer:
when you replaced the thermostat did you put in the new o-ring on top of the thermostat?
i JUST bought it.
the PO had it replaced...i'll have to check
Symptoms are consistent with missing that o-ring. This is often not installed. Coolent flows all the time, so engine temp goes up only when worked hard (like on a long hill). I'd purchase an o-ring before opening it up....
interesting...ok i'm going to check that out ASAP
thanks
