engine swap
San Jose CA
I just got a 73 F engine w/ 4 spd tranny. My '70 F blew. When I swap them will there be a problem w/ the driveline length or do they just fit right in?
Poser
Oh...Durka Durka Durka.
s-Moderator
Supporting Vendor
MN
The engine will not change anything in this set up...
If you are replacing a three speed tranny with a four speed tranny, you will need to find the driveshafts from the four speed truck, or have yours changed....
Good luck!
-Steve
Orem, UT
Good luck!
-Steve
Where are you located? I might have these in my garage. Also, I would keep the 3spd. I've heard that the 3spd actually has a lower first.
- Rico.
- Rico.
The 3spd TC has a lower low than the 4 spd TC,but the 4 spd trans has a lower low than the 3spd trans.
