My 100's engine started to squeal (short and not loud) few weeks ago, but usually only on the first crank in the morning when I start the car in garage, that's it. Rig received fairly major service three months ago-
replaced timing belt
-drive belt
-all related tensioners, pulleys
-fan bracket, fan clutch
-water pump
-oil pump seal
-oil change
-ATF, Diff oil, brake fluid
-coolant, radiator
-lubed all driveshaft fittings
All OEM Toyota parts.
What could be the cause of the squealing? This is my daily driver and no other symptoms noticed.
-drive belt
-water pump
-oil pump seal
-oil change
-coolant, radiator
