Sweet, thanks Josh. A few pics may be all I need. Then I can go ahead and do a proper HOW TO for future installs.
Damn, I have to remove the battery box? That sucks. I've only got one useable arm so thats a no go until I can get an extra set of hands. Hmm....
I don't completely agree with removing the battery box, you can see in the previous picture I am using a 10mm ratcheting box end wrench to remove both bolts. ( keep these you will need them to secure the outer water bottle). I was able to gain enough hand room by release the battery hold down and push the battery out of the way.
What goes into deciding the use of 10W40 vs 14W50 etc for the 80 model?
VanGo said:I don't completely agree with removing the battery box, you can see in the previous picture I am using a 10mm ratcheting box end wrench to remove both bolts. ( keep these you will need them to secure the outer water bottle). I was able to gain enough hand room by release the battery hold down and push the battery out of the way.
You will see the room is tight in there but it can be done without removing the bolts. When I did remove them I was able to push the top of the battery box towards the front of the rig to give just enough room to get the box in there without forcing it. To each his own but again I did NOT remove the box, just the few bolts in front to move the box out of the way.
