Hi All,
I bought a used engine a few weeks ago from a Landcruiser salvage yard in Utah. The engine has 148K miles on it. My plan is to replace all seals, head gasket and whatever while you’re in there to bring the engine to its top shape and swap it with my current engine at 272K miles.
First thing I did was take off the head and sent it to the machine shop along with other bits and pieces to get cleaned.
I got the head back from the machine shop about a week ago but before I put it back on I wanted to replace the rear main seal and upper/lower oil pan seals. A couple days ago I had a fellow mud member help with the rear main seal. Today I started on cleaning oil pans and completed putting it back together with FIPG.
Next was the head. I put the OEM gasket in and torque ARP head studs to spec. Then moved on to dropping in the exhaust valve shims. Everything went smoothly but I had issues getting #4 and #5 shims to drop in place. Upon further inspection I noticed some marring on the head of #4 and #5. The worst is on #5. I don’t want to force them in at this point.
I think the machine shop muck them up. Attached are some pictures of the marring. What are my options at this point?
