Engine noise up front...Can't make it out??
КАГІҒОЯИІА
My truck idles at about 860 rmp, a little rough but not too bad.
When it idles, it makes a noise from the front, of the engine area.
Cannot quite explain it but it is kind of a bearing-ish noise with a squishy rubber innertube type sound thrown in. It has a rythym to it.
The closest I can pinpoint is around the alternator on the driver's side but very hard to isolate.
Funny thing is that it only happens at idle and on up to about 1000 rpm then it disappears.
Belts are from a the Toyota dealer.
Is there anything known to fail up here in the way of bearings?
But if it is bearings, would'nt it make noise at high rpm's as well?
Truck has 186K on it. I can hear the injectors clicking so it is not too loud.
Any ideas? Or "ideeers" as my co-worker from Boston would say. :D
Also, has anyone ever done the AUTORX oil additive in these vehicles to remove sludge and varnish? I did it in an old Audi I had and it worked very well.
Thanks for help.
:beer:
Whitey said:
When it idles, it makes a noise from the front, of the engine area.Cannot quite explain it but it is kind of a bearing-ish noiseFunny thing is that it only happens at idle and on up to about 1000 rpm then it disappears.
Belts are from a the Toyota dealer.:beer:
The idler pulley has been known to make noise. Do a search for that. I am sure others will offer advice on it.
Second the idler pulley. I had a similar, very noticeable at idle, noise from the same area. I took off the idler pulley by the alternator, restarted the truck and it was gone -- idled nice and smooth and quiet. The bearings on the idler pulley are sealed, and although mine spun freely and quiet off the vehicle, I chose to spend the $25 or so to replace it. That and new OEM belts quieted everything down.
Check your air pump also. I had a rythmic high pitched whine going on under the hood and tracked it to the air pump. I hit the shaft where it enters the pump with a little white grease and it went away and has not come back...Mine is a 92. Your 93 may have the same config...may be worth a look
No air pump on a 1fzfe.
I would not go there.
The idler pulley is the little one that drives nothing.
It is merely there to stop any vibration on the belts from what I understand.
I was convinced mine was bad from the whining up front.
Increases with rpm, decreases with rpm.
I had gate belts and replaced with OEM and was amazed at the difference.
Start with the belts if that does not get it then replace the idler pulley.
When I got my LC I noticed the same noises you have, I changed all the V belts, didnt bother with idler pully as it don't do much really, and it all went quiet after that, belts may look ok, but they do tend to glaze up on the edges, and you will also notice when you change them, they ride a little higher in the V of the pully, which is where it should be.
Almost sounds like it is coming from the inside of the front of the valve cover...
Perhaps the timing chain?
The belts are all mitsubishi and according to the paperwork, 15K old.
I was mistaken before, truck idles at 660 or so RPM in park and noise is loudest around 800 RPM then disapears.
I took off the idler pulley, very simple, still made the noise....
Still scratching my chin...
