In need of some advice.
Backstory: I’ve been chasing a P0401 code. Took intake off, replaced all vacuum lines, cleared my vacuum port through the intake and relocated my VCV switch. Put it together and my light comes back on. No big deal. I kind of expected that. Vehicle ran fine.
Fast forward a few days to this past Friday and it starts running super rough just after filling it up. Code comes back as a cyl 6 misfire, and later 5 and 6 + random misfire codes. I did a full tune up to see if that would remedy the issue, but it did nothing. I did some research and I assumed the harness next to the EGR pipe had damage. I was working in that area, loom is melted, and it just made sense that that was the issue. Harness looks like it’s taken no damage in the area. Connector to #6 injector looks fine, no corrosion to it or the injector itself. Before I took it apart, the injector sounded like it was firing while listening through a stethoscope. I’m just at a loss of where to go next. Should I just throw an injector at it and see what happens? Could the EGR issue be causing my cylinder 5 & 6 misfire? Should I pull the valve cover to see if I have an issue with the valve train?
Some guidance would be greatly appreciated.
