Basically ...it just does not idle. As long as I am pumping the gas pedal, its great; but as soon as I let go...its off!
I've checked the fuel cut-off solenoid cable, with key in ignition, I can hear a slight clicking noise if I discount / re-connect the cable. I've checked my fuses; they are all good.
2+ weeks ago had the same problem; the mechanic replaced the fuel filter and disassembled / cleaned the carburetor. So this time, the fuel filter is clean. I did not take it out to check the flow but looks clear with no visible dirt / debris inside.
I'm totally stumped...would appreciate some advise.
