Engine Codes?
Discussion in '80-Series Tech' started by hpantier, Feb 23, 2004.
  1. hpantier
    hpantier
    113
    Feb 4, 2004
    Tried a search but no luck on this...i know it is a pretty simple question...but how do you get the engine codes when your check engine light comes on?
    Once you have the code is there a site (or place on this one) where you can look up what that code means?
    Also how do you clear the codes to see if they come back or not?
    Thanks for your help and sorry for the lame question.
  2. SeanAndHis80
    SeanAndHis80
    561
    3
    Apr 10, 2003
    Chester, NH
    Either buy an OBDII scanner, go to Autozone (free), or another mechanic (cost will vary).
    The factory service manual, an aftermarket manual, or just ask in this forum. It is most likely going to ne the P0401 code - that is the most frequently mentioned cause for a MIL (or CEL if you're old school)
    The OBDII scanner will do this, or you can remove the backup ECU fuse.
  3. e9999
    e9999 You want to do what...? Moderator
    16,629
    513
    Sep 21, 2003
    US
    go to the Harbor Freight web site.
    Look for the manual file for their OBDII reader ($40). (Works fine, btw.)
    IIRC it has a full list of codes.
    HTH
    Eric
  4. hpantier
    hpantier
    113
    Feb 4, 2004
    welp the jury is in it's throwing a P0133 code (O2 sensor circuit slow response - bank 1 sensor 1) - so i guess i need to replace it. One question, i don't have "the good book" (FSM) yet...would anyone like to tell me where this is.
