Engine bay bracket for fuse blocks, etc
  • Thread starter CruiserTrash
  • Start date
  • Watchers 3
CruiserTrash
CruiserTrash
Denver
As with all things Land Cruiser, I had a simple task - upgrading the alternator wiring - that led me down a deep, deep rabbit hole. I wanted a fuse block to hold a larger fuse for the upgraded wiring instead of a messy inline fuse, but I had nowhere to mount a block in the engine bay. Did some kind of bracket exist? Nope. Could I make something with a hammer and cut off wheel in an afternoon? Probably, but it would be ugly. Did I want to relearn CAD for the first time in 20 years? Sure, why not.
This the the first prototype of the bracket. It needs some tweaks. But I have it installed in my truck. This is CNC cut, bent 304 stainless steel. You could mount dual battery or solar panel gadgetry to this thing too. I'm using it for fuse and relay blocks to clean up my engine bay wiring, and ultimately to bypass the fusible link with equivalent slow-blow fuses. There's a possibility I could further tweak it so an air compressor would fit, too.
Would anybody be interested in this? Sorry for the crap photos: one is the bracket laying loose, and the other is after I finished the alternator wiring in the dark. I'll get some better photos tomorrow.
1435DA77 FC98 4134 9105 95780BAA6EEB
A5F17FF4 5E72 4E4B B2D6 DB092C89CB67
CruiserTrash
CruiserTrash
Denver
35EBEAC9 02FE 47B9 A9C0 3573E021D502
7EC6BFE5 8348 4317 93B7 B06C5E8B4743
54256C32 B95C 46F5 B0F7 699AFF68A2C0
As you can see I had to modify the "foot" - it was a hair too long. Cut off the end and re-bent it with a hammer over a piece of angle. Crude, but I just wanted to get this one in. The foot lands on a flat spot on the wheel well and requires drilling a hole. Trigger warning for you "it's gotta be untouched OEM" freaks!
Other than the foot, it mounts to two threaded holes in the passenger side wall of the engine bay (M8x1.25, plus a spacer).
The vertical face hanging down towards the engine is for things that side mount like the GDC modular relay block I have. The small vertical strip hanging down towards the battery with the thin slot is for attaching zip ties or whatever to help with with cable management.
The top platform is roughly 11"x9", so there's lots of space. That fuse block I have is enourmous.
Revisions for round 2:
Thicker gauge stainless (it works well but is a little floppy for my taste
Fix the foot dimensions and possibly add a 2nd foot
Make the slots only go halfway across the top so the structure is more rigid (probably make the metal between slots alternate like a layer of bricks)
Possibly lower the relative height of the platform if that makes commonly used air compressors fit under the hood
Anything I'm missing?
270FF73C 292B 4260 B2D3 A9FCF8D73245
CruiserTrash
CruiserTrash
Denver
Thanks @OSS - looks good! The main internal section of my fuse box is waterproof, but the outer lugs are not. It's unlikely that some stray water from rain or whatever would cause those to short, but it could be a weak point under heavy water or during a deep water crossing. Luckily the hot, ground, and fused hot lugs are all on different sides so they wouldn't easily short. The Pelican case is a pretty cool idea for complete waterproofing though.
dbbowen
dbbowen
Memphis TN
Looks great! You ought to design one to replace the little holder bracket for the Headlight washer bottle too and use those same mounting holes over there for people who have ditched the dumb headlight washers!
CruiserTrash
CruiserTrash
Denver
Can you send a photo? I have an 83 - no headlight washers.
tmxmotorsports
tmxmotorsports
OBX Nc
Hereis what i did on an 1984fj60 i did an ls swap on needed extra power amd stuff for power seats n stuff. Wasn't cnc cut was built by me for the bussman box and circuit breaker hides some of the wiring qith the boxed design. Was a one off bracket .
Tommy
Screenshot 20211127 163106
CruiserTrash
CruiserTrash
Denver
Tommy
Nice. Looks like some pretty heavy gauge bent steel?
dbbowen
dbbowen
Memphis TN
I mounted my arb compressor there and don’t have any pics unfortunately. This would have helped a lot for me mounting the compressor haha
Similar threads
Advent
Replies
4
Views
148
HemiAlex
HemiAlex
1
Replies
9
Views
243
Skniper
Skniper
Silveredition
Replies
4
Views
195
2mbb
M
Replies
2
Views
123
ModisetteDad
M
