I've heard that a person can do a reasonable job of basic balancing on their rods/pistons themselves. I have an electronic scale that measures down to 1 gram. Can anyone give a brief tutorial on how to do this correctly?
My guess is: You assemble the pistons/rods/rings/bearings/caps after they come out of the hot tank clean. Then you weigh each assembly and find the lightest one. You then lightly grind material off each assembly until they weigh the same? If thats correct, where do you grind the material off? From the rod cap itself? Are there any other components the average person can sort of balance themselves without too much risk of screwing something up too bad?
