Eliminating vacuum shifter on 3 speed transfer case on 69 fj40 (1 Viewer)
Once I remove vacuum shifter on my transfer case, can I eliminate the shifter on the dash?
Floor shift conversion accomplishes both 2/4 and high/low. On the dash there is a linkage and a pull for the vacuum actuator
Ryan: Much Thanks for response. Are you saying, that I can remove the dash pull and linkage-will not be needed?
The linkage that does away with the vacuum shifter includes the high low. Not how common the shifter is to find. Same with a custom twin stick setup. Four speed are a lot more common.
Just curious. Why are you swapping it out?
I have one the the manual floor shifters I'd sell you. 2 actually. I think I am missing a plate that goes with it. In the schematic it's #2. It looks like you have to be careful to get the 3 spd shifter not the 4,5 speed shifter.
