Ryan: Much Thanks for response. Are you saying, that I can remove the dash pull and linkage-will not be needed?Floor shift conversion accomplishes both 2/4 and high/low. On the dash there is a linkage and a pull for the vacuum actuator
Thanks for your response.The linkage that does away with the vacuum shifter includes the high low. Not how common the shifter is to find. Same with a custom twin stick setup. Four speed are a lot more common.
