I'm at my wit's end with the electrical system on my poor '71. Pretty much all of my posts on this forum have been related to it in one way or another. I just want it to run again so I can take the top off and drive it a little while the weather is nice. No more deep water, I promise
Anyway, the starter solenoid was bad, I replaced that. The battery cables were all nasty/corroded so I replaced them. The alternator was bad, so I replaced it. All this went bad mind you at once, after a little swim. I don't know what or how, but a little dip in a water hole has completely killed everything electrical on this whole truck. It wasn't really even that deep :whoops:
I can wrench all day long, but I'm no electrician, so I gave up and took it to a local automotive electrical diagnosis expert. He played with it for a little bit and decided the ignitor is bad, but he can't find a replacement. Like I said, it's a '71, but the previous owner swapped the drivetrain for that of a '78 or '79 (2F, 4speed, etc) so I would assume this makes it the full electric ignition. Where does one locate a new ignitor or a suitable replacement? The electrical guy says that if it's possible it might be cheaper and easier to just put an old school points/condenser ignition on it. Is this possible/easy? Like I said, I just want the poor thing to run again.
Also, despite my lack of electrical knowledge, I'm not entirely convinced that this is the only problem. In my time tinkering with it I found that although I get a voltage drop at the battery when I turn the key, I don't think I really have any juice in the system. The headlights and stereo do not work, with fully charged batteries and the key in or out, on or off. I recall reading about a constant power connection something or other from the fuse box to the starter maybe? that would power these items. Would this prevent the beast from starting? Any other ideas?
The noob says thanks.
